For what it's worth, these guys are definitely taking you in the right direction! Kyle, it's good to see another on here working in Pro/E and running FEA. The only thing I lack is access to a Faro arm (I work on my own).
I'd have to go back and review my mohr's circle to tell you for sure, but I think you're ok here looking at the simple loading. I believe Mohr's circle comes in more when you have to take several loads and resolve them into pricincple stresses and shear loading to make sure that a part won't fail. (Think tip load on a road sign at the edge and you want to see if it shears off at the base).
I really don't think we need to dig into herzian contact stresses here. That comes in more whith repeated cyclic loading like bearings and gears.
About the only thing might be fatigue, but since we're using steel we should be able to make sure we're covered by a safety factor on the s-n curve. (Fatigue strength is manageable in steel since it levels out over time)
http://en.wikipedia.org/wiki/Fatigue_(material)
Kyle's going to be wathing for that and making sure you don't have any stress concentrations in your design (No sharp corners, nice uniform welds).
other than that, the build is awesome and kyles definitely taking you the right direction.
Kyle, I'm assuming you've got it too, but I've got a my own seat of Mechanica and also can help by running stuff if need be. We could also look at running Greg's design in mechanism and making him a little movie of the motion....
-Ben
-Ben
