Brian_D
Love that green color, i use that color a lot when doing paintings. good job!
From what I understand the newer STX ORIs don't have as much of a set ride height spot like the older STs. They still recommend at least 5-6" up for any of their shocks just so you aren't sitting right on the bump portion.
http://www.pirate4x4.com/forum/15051052-post24.html
I think in the old days it was accomplished with different length internal tubes and a bit less shock oil.... not sure that all of that is still necessary... maybe just remove a bit of oil?
Heath,
Yeah, I think 16" up front is unrealistic. Miniwally recently commented that having a little less wheel travel up front (vs. rear) is actually a good thing, since it keeps the truck more stable at speed.... something about having a little extra "margin" out back to absorb bumps to keep it from trying to swap ends.
At my current belly height (26") the best I'm going to do up front is 6" of uptravel before the axletube crushes the oilpan. Realistically, I need to leave myself some room for error so maybe 4-5" is my TRUE maximum for bump.
The main reason for the effort with the 4-link is to keep the axle nice and centered under the truck under compression / articulation. Every panhard bar design I've seen and tried mocking-up myself ends up spitting the axle out one side of the truck by a few inches under droop. It seemed like a bad tradeoff, but perhaps the amount of "error" at reasonable wheel travel numbers is so slight that it's not worth worrying about?
From all the suffering I've already done trying to package the 4-link, I can totally appreciate why almost everyone does a 3-link instead. It feels like I could get one of those roughed-in if given 8-hours or so of uninterrupted time in the shop!
Got a link to any good "wristed" radius arm setups? I know theres a lot of torsion in the axletube with the solid mounted radius arm setups, but I haven't really spend much time looking at that type of solution in several years.
-G
His point back then was the same as yours... don't put a super-capable suspension under a rig that isn't ever going to take advantage of it. I tried to take those words to heart, and that was at least the impetus for the "transformer" idea. I can pull all the exterior sheetmetal for wheeling and that will allow me to worry less about damage. Ultimately, I still intend to drive this thing a lot on the street and just enjoy it that way as well... so a true buggy-style rig isn't going to make me happy. I'm trying to "thread the needle" with a true dual-purpose rig, and that is a difficult thing to do.
Pinion change is also basically going to reflect the amount of caster change as the suspension cycles too, and although I'm not building a desert runner... I know that massive changes in caster can be pretty miserable too.
Now for my dumb question(s):
If I was to build a 3-link based on the configuration I've got now (PS drop Atlas) would I put the 2 links on the passenger side, with the single on the driver's side? Presumably this would leave me room on the driver's side for the steering linkages.
In that configuration, which side does the panhard frame-side mount go to? Drivers side or passenger side? Or is it just a function of keeping it aligned with whatever steering draglink I end up with (parallel)??
-G
As for the 3 link configuration, that is up to you, and it will be tough with the portals. You could do the 3rd link on top, at left or right. Or you could put it in the middle on the bottom (it would have to be VERY strong), and put the side links on the top. With long tubes it will be tough to do a 3 link, but without longtubes you will be giving up noticeable power with that 502.
The thing I'm worried about is how much stress the portal axles will put on the odd link. Has anyone done a 3 link with portals?
