A couple things (again)
Yes, the cab supports are frustrating because they don't give you a good "index" for the 4-bolts area. I decided to cut them vertically on the side that is closest to the bodymount bolt then bend/rework it to fit and weld in extra metal in the "v" shaped gap that I ended up with. It's a shame that you cut off both sides of you truck at once...now you don't have a reference for dimensions anymore.
For the doors, you might do OK by measuring straight across the bottom of the door area (where the verticals start)' then measure at the highest spot you can too. Ideally the dimension should stay the same. If it's smaller at the top, your body is sagging and you'll want to deal with that BEFORE you weld in any new metal.
A simple bar welded between the upper hinge area and the sticker plate would be a good start. Shim it, or adjust it with a piece of threaded rod until you get the dimensions consistent. Check those values against your door skins as a sanity check. With body gaps, you'd probably see the doorskin is about 1/2-5/8" narrower than the door openings.
As you already noticed, the entire windshield/cowl area gets pretty floppy when you cut out the rusty metal. Take you time and measure everything carefully. If your measurements are off from side-to-side spend the time to figure out why and correct it. Otherwise, you'll never get the doors or front fenders to fit right later on.
Good luck.
-G
Good luck.
-G
