73-80 front end on 84?
one ton burb
Ontario, Canada
Ok I know there has been a lot of post on putting a newer style (81 to 91) front end on older trucks but this is the other way around, what I want to know is if i could put the older style (73-80) style front end on my 1984 burb as far as i know just the wiper's are diffrent because the older front end dose not have a cowl cover and hte hood goses all the way to the window covering the wipers, so what mods if any would I have to do to make it work?:confused:
thanks guy:bow:
Tom
73-80 , the hood hinges and everything is mounted on the fender .
81 up , hinges mount on cowl , springs between hood and fender .
I've only ever had the older style, but based on what's said here, seems like if you swap hood and fenders from the donor truck it would work ok...but I don't know if the cowl is going to interfere with the old-style hood...
You will need the wiper transmission (linkage) and pivots from the donor '70s truck as the studs for the wiper arms are shorter. I've done this conversion, I put an '84 cab on my '79 K10.
