73-91 Crew Cab Parts Needed
82crewcab
Registered Member
Casey,Ia
I am looking for a headliner board for my 82 GMC crew cab. I have all the plastics I just need the board for it. Mine got ruined by the guy who stripped the truck down prior to me. Also need blue seat belts mostly for the back seat.
I am located in west central Iowa and will travel a reasonable distance. If you have any of these or a fairly parts truck with these please let me know. Thanks in advance
Do you know if belts from a regular cab would work for you?
I have a truck with blue belts in good shape
It would make sense since the rear of the crew cab is the same as the rear of a regular cab :)
parts
No the belts are slightly different plus since mine is an 82 it only had lap belts in the rear. I finally did find my belts on ebay and got them for less than 30 bucks for all of them. Still looking for more stuff though.
Bolt in trany tunnel with four bolts along the sides. I have two different tunnels here and they all have 3 bolts only and are too short on length.
Headliner board.
More to come for sure. Please let me know if you have any of these. Thanks
Casey
Small world. I just bought my place here about a year ago. I am actually from Atlantic but I work in Des Moines. Its a good compromise between the drive and cost of living. Ever go to the Gutherie Center mud drags?
i have a 1980 crew cab, it's blue also. what do you need, i will be scrapping the cab. it has a manual trans so it should have the tranny hump you need.
parts
I need the traany hump for sure. Rear seatbelt buckles in the center of the seat. Does it have the headliner in it?
i think so, i will check tonight on everything and get back to you tomorrow.
i have the rear seat buckles. the headliner and boad have little boards and screws holding the liner up. i didn't pull the carpet the whole way back, as i didn't have much time this morning, but it is bolt in. let me know. i can sell you the buckles now, since they should be easy to get out, or if your not in a hurry, i will be taking this cab apart once i find a regular cab for it.
parts
I am not in a huge hurry. I bet the hump is the same.As long as there is 4 bolts down the sides of it it is what I need. If it has 4 bolts consider it sold. My trucks cab hits the bodyshop in 3 weeks and then its gonna be awhile till I need the belts so we might as well wait it awhile.
