73 K20....crossmember time
Got the xj shaft on today. It had some sort of glue I had to melt with the torch so it would telescope. I managed to kill the piece that keeps the seal and stuff inside the column as you can see. I've found one parts guy online and it's 76 bucks. I'll have to keep looking. The steering shaft is sloppy because of it.
Looks like you need a column lower bearing and you need to weld the top of that XJ shaft. The ears on both side. I will help 100%
Started taking this nasty thing apart. Might have it all boiled out before I machine on it and out it back togethor.
My steering column parts are here so I can fix that too.
I managed to buy the wrong sized angle iron for the crossmember. I'm going to try to find some larger stuff nearby tomorrow.
