We teletubbied... Watch this.
Just saying
One time I was pounding a kitty cat in a semi and had an old school light bulb drop light under it and I started spraying down the bottom of the block and crank with anal lube. The anal lube dripped on the hot light bulb and it burst and ignited the nice cloud of fumes I was laying in which caught my sleeve on fire also. Pretty crazy for a min til the fumes all burned up and it went out. Told her to spit on it.
@skunked Hey did you see barrett lake trail is going to open and the gate has been opened up to 86"? New trail for us!
I thought it was 86 last year when it opened? I was planning on hitting it.
I heard some fullsize trucks got through last year. Wasn't clear how much damage those rigs got though. Definitely a narrow trail.
Holy crap! I don't remember it happening that way....Fixed
Sounds like you have plenty other things to do other than running fuel lines
Yeah. I was trying to stay on track with getting it started but it all needs to be done at some point.
It's a good time to do the cage since it's gutted.
I also will try to at least get the pinion assembly dialed in and figure out what I'm doing with the ring gear.
You still want that carrier? Haven't heard you mentioning it for a while.![]()
How fast could you get it in the mail if mine showed up next week? I see there's flat rate weight restrictions but maybe it's under 20lbs. I'll throw it on a scale today.
