Thanks. Someday I'll even be able to drive her =))81K5GUY said:nice build up
-- A
-- I'm also doing a lightbar, as dangit, I've always wanted one. I'm sure I'll find it ridiculous when I'm done, so I've designed it to be removable from the rollcage ... this also assists in getting the truck into the garage, should said garage ever be clean enough to fit a vehicle into ever again. But I digress.
lectric80 said:So where does the radio go now?
I couldn't live without a radio, even added Sirius so that I can listen everywhere.
The farthest outside set of lights needs to be adjusted some -- I used a piece of flat stock in the center but had to extend it a bit on each end and my extensions weren't flat.
... and it throws down extra light in front AND makes the truck even more rednecked, which is about its intended purpose
... though the next one I make might actually be straight
your not going to be able to see anything without more lights then that.
do you have them all angled different so that you have a wider range of sight? or are they all straight so you can burn ants during the day with them?
gmc4cw said:the switch panel looks almost factory.![]()
but next time I might do square tube. Though, especially after some Bondo and painting, and from a distance, the round looks pretty good with the rollbar. It's only when you get close you say "Aaron what DID you do to that thing?"
broncoman6524 said:NICE!! im likin it...kinda shiny though aint it?![]()
I agree with chas...that panel looks factory...
you seen the steering box brace on the trazer?
Yeah but I have no way to bend or weld them right now...And Dafey, pipe ain't that expensive![]()
Well, it ain't your truck ... but it never would be, too much rustCraig Artzner said:Wow this was quite a build! I just spent a half hour reading it. Nice!![]()
My wheel wells, the rears particularly, were trimmed on the basis of cutting out rust more than tire size, grrr. Still, it's fun... and I dream of someday finding (and having a place to put) a stocker like yours
primerk5 said:What did you do about the wiring. Did you put in any breakers or maybe relays? I need to get mine wired back up. I have the 150 watt KCs. I think that is what they are.
dremu said:A pair of 150W lights would mean a 25A load, so you'd want a 30A relay and a 25 or 30A fuse, fwiw.-- A
Man i was really into this til i couldn't see the pics anymore. that was a bummer
