74 Olds 455 in a 80 K5
yup, be perfect for a tunnel ram...
can't say I ever ran a ram.. just wasn't very DD'er friendly... even in the 90 cents a gallon fuel days! :haha:
I am putting it on my K30. Since LPG takes up some of the room in a big port (since it is vapor) and I thought the long runners would help the torque. Plus to 450 cfm carbs would be about right. I can get lpg much cheaper than gasoline right now. I will chassis dyno it to see the gain.
definitely a cool, nostalgic, nasty look fo sure...
hilborn out the hood baby!! :saweet:
:bow: :popcorn: :woot: just sayin... ;)
just standard 6" rounds will prolly be easiest..
What would I need to get it to fit? I know new motor mounts but are there factory ones or will I need to make them? I think that might be all I need.
If you have all the parts and have the ability (and can do it cheaper than bbchevy), do it.
I have an 80 blazer with the 73 455 olds, was a little bit of a hack job when it was put in, so I am no help as far as getting it in. Motor came with a complete car for 25 bucks. Stock for stock, this thing would stomp a 454 chevy.
And I agree fully, that a bbchevy is a good looking engine.
the BBO is just flat ugly
Its a complete engine and trans for $300 obo.
I don't know anything more than the guy bought it last year for a project and never got to it. It is sitting in a tire, covered in a tarp and the trans end is wrapped in a bag. I would deff. check it out better once I went to look at it.
If it works great, if not I'd see about a rebuild kit or how much it will be worth for scrap.
You'd need to gut the Olds tranny and install the 4x4 output shaft in order to use the Olds engine,or use an adapter plate between your existing chevy tranny and the Olds engine (about 70 bucks from Jegs or Summit)...unless you happen to have a rare dual bolt pattern bellhousing tranny already..
I have a friend who has a '69 C-10,when he bought it someone else had put a 350 Olds rocket and TH400 trans in it from a crashed '72 Cutlass,it ran very well ,but he is a bit of a purist,he put a 350 he had back in it with a TH350 that was built up...the truck also had the Olds Cutlass rear axle swapped into it,he ended up finding a chevy stock 12 bolt posi for it instead...(truck was like showroom condition,he said he would not have bought it otherwise due to the drivetrain mods,but whoever did the swap did a decent job)..
He sold the Olds engine on craigslist ,only took 2 days before someone offered him 250 for the engine,and he gave the guy a deal on the tranny,for another 100 bucks...
Olds and Pontiac engines are getting scarce around here and sell quickly,even if in need of rebuilding,you cant even find a good core usually..so if you decided not to use it,you'd probably get your 300 back fairly easy if they aren't common in your area still...scrap is down though,a complete V8 will only bring maybe 50-75 bucks for scrap around here...I'd say it'd pay off to put ads in craigslist and hemmings and you'd have no trouble selling it...especially a 455,muscle car guys are always looking for them,running or not..
