'75 Blazer RPO Codes
db75blazer
Milton, GA
Sorry guys I have a newbie question. Just purchased my first blazer (a '75). The options sticker is gone from the glove box. Is there no way to get from GM or somewhere the information that would have been here? Thanks in advance!
Check the driver side inner fender under the hood sometimes the sticker was placed there.
On pickup trucks,If the seat is original ,look in the back side of it,I have found a few build sheets stuffed under the springs...also saw one truck that had it stuck to the rear cab wall under the rear window,hidden by a cardboard liner..On a K5 though,it may be hidden anywhere..A few I've owned had it glued to the drivers side inner fender under the hood...
I found the build sheet for my 81 G-10 van stuffed up inside the unibody frame rail near the sway bar one day when I was lying under it changing the oil--saw a hunk of paper hanging out of the hole,thought it was money at first--was surprised when I fished it out and could still read most of it,this was when the van was at least 20 years old!..
