X2, I would rather see you keep it.dont sell it you will regret that decision
And I ended up ordering a new d-shaft from HAD
don't mean to hijack but what headers are you using? I want to get some for my caddy in the blazer.
Engine:
547 Stroker Caddillac. Original 75 model block & crank. Crank was offset ground to achieve longer stroke, nitrited & all rotating assembly was balanced. Eagle "H" beam rods 6.800" length for BBC w/ "P" race bearings. Ross pistons. 1970 model "950" no smog heads. Heads were port matched & bowl ported. Larger valves & springs installed. Potter shaft mounted adjustable rocker set-up. Custom grind Comp Cams camshaft. Edelbrock Performer intake. Jet performance stage 2 Quadrajet. DUI distributor & plug wires. Flowcooler water pump. West Coast Innovators Harmonic dampner. MTS SFI flexplate. Griffen radiator, Flex-a-lite dual electric fan & controller. Mains & heads are studded with ARP fasteners. Eldo oil pan. Custom made headers. Bulldog cast alum valve covers. 140amp altenator. Carter muscle car series fuel pump. MTS gold oil pump.
