mtnman210
This has been a project truck for 2 years and almost all components are brand new and never used. I would like to sell the whole thing together and not part it out or do any trades. I hate to get rid of this before I get to finish it but if thats what has to happen....This isn't 100% sure yet but I figured I test the waters just in case.
77 blazer
interior completely removed
14bolt open 3.73 gears with DIY spring perches
Dans 60 front open 4.10 gears (new kingpins and seals), DIY spring plates
NEW never run 6in Skyjacker soft rides springs front and rear
NEW 2in body lift
NEW 15x10 MRW HD 32 bolt beadlock wheels
39.5x18x15 Interco Boggers 99% tread left
NEW in box cross over steering kit from North West Fab including all tie rod
ends
NEW in box AlloyUSA 4340 axles for the Dana60 (35spline outers)
(2) NEW Corbeau Baja Ultra SS suspension seats-black
(2 sets) NEW Pyrotech Full 5point harnesses
Th400
NP205 transfer case
4 core radiator
454 big block: the motor has been torn down to the block. I have all the old internals to put it together but it needs either a new crank or the current one ground to fix some scaring.
All the Air Conditioner/heater stuff
30 gallon gas tank
Along with this stuff will come
an extra starter
Dana 44 that is missing a couple pieces but is in great shape
th350 transmission
np203 transfer case
stock blazer seats, have seat covers since the originals are a little stained.
stock back seat--again is in not the greatest shape.
a set of roller tires and wheels for it
old 4in front springs
4in blocks for the rear
and what ever else I'm forgetting....I need it all gone
Most have seen the build thread for this truck on here: http://coloradok5.com/forums/showthread.php?t=158196
If you have any questions please ask.
This is located in Southern California.
I'd like to get $10,000 obo for everything
These are the most recent pictures I have at the moment I can take more a little later. Again everything is there to have make the truck functional and it should be a great play toy.
77 blazer
NEW 2in body lift
ends
Th400
NP205 transfer case
4 core radiator
30 gallon gas tank
an extra starter
th350 transmission
np203 transfer case
