^ what he said, the metals need to be clean to weld together, including were the ground is attached.
Yea, dumbass me painted it with POR 15 first. I forgot I had the frame braces. I only painted the driver side frame rail. The passenger side hasn't been touched yet. I sanded off the POR15 down to bare metal before I welded.If it's POR15 there's no way you're gonna be able to weld through it
Would seem to work but mine isnt bolted to the floor.....A press works good to hold it also. Provided you have a press that won't move around.
I think I may have the same issue as you. Just a little ocd. I have also torqued the bolts on everything being reattached to the frame.Those should be just fine when you tighten the bolts. I torqued the bolts in mine since I went OCD on it. Not usually working with 7/16" bolts anyway.
Nice progress BTW!
