77 C20 hauler to crawler
I'm kind of confused on this pump. I have two of them and on the side it says max psi 125 but when I look up the part number it says 40psi? I know when I had one hooked up and my regulator was screwed up it showed 90 psi on the gauge. And yes it scared me. Lol
based on the reviews I would carry a spare pump even if it does supply enough fuel.
and why not just do an in tank pump? The declo is like $40 and it's going to be quieter, stay cooler.
You have a part number by any chance? I thought I had something different than I do. Chances are it will work, but chances are it won't. For $40.00 I can justify buying another pump, and I totally agree with doing an in tank setup. Pushing and pulling sucks... The less it has to pull the better.
EP381
The tank and sending unit is for a TBI Blazer right?
whole discussion about it from the other day https://ck5.com/forums/threads/acdelco-ep381-question.327200/
Is the opening in the tbi tank the same as the non tbi? I'm pretty sure I have a sending unit for a tbi tank that I can modify
