chevyguybc
i know im not a member, yada yada, this friday i will be, anyways... truck is done with thanx to you guys about 52s awhile back
PICTURES AT BOTTOM, READ IF YOUR INTERESTED WHATS DONE!!! WHATT! YEEA!
i started the project january this year... swapped out 4 inch lift on 35s, half ton.. ****ty motor...
now has 14 bolt welded
dana 44 welded, warns, upgraed axle u joints, lifted steering arm, dropped drag link
lifted rear 52s with overload and lower leaf removed...custom front crossmember and square front shaft are done but need to be installed, this tuesday..
4 inch blocks and shackel reversal..
305 now has hooker comps, 3 inch straight pipe, performer, cam, new dist with lighter weights/springs.. 1 inch spacer, rebuilt tuned quadrajet...
36X14.5/15X10S
the 305 4 bolt main is a canadian truck block and it just rips
ENJOY THE PICS
36X14.5/15X10S
ENJOY THE PICS
