77 k5 383 4" lift new mud tires in North NJ
84CUCV
3/4 ton status
NJ for now
383 th350/203 1/2 ton axles new 33 bfgs. runs good. needs a bit of work.. needs some new lines. not much rust. some in rockers and tailgate as you can see. be a great truck to wheel. call if you like 732 966 6841
does the blazer run and drive? do you think it would make a trip to PA? what kind of work does it need and what lines does it need? D44 front axle and 12B rear axle?
is there any particular reason you would tow it if the fuel line and filters were replaced? how are the brakes and the brake lines/hoses? it doesn't look too bad from the pictures, i figure if i spent a day on it, i could get it roadworthy to drive back to PA. i guess its been sitting for awhile?
