1977 Chevy 4x4 K5 Blazer 6in. lift project that needs to be finished, I have the parts to finish it just needs to be done. It was running and driving, put it in the garage to replace the rusted body panels and just haven't finished it. Colorado title. It has a topper with sliding side windows.
Installed it has:
35x12.50x15 tires on aluminum wheels with spare on a new black steel wheel
Front winch bumper with mile marker 9500 winch with synthetic rope
Front tow hooks
Front mounted trans cooler with electric fan
Front mounted trans filter
1/2 ton axles- front 10 bolt 373 gears with lock right locker and diff guard, disc brakes, dual shock steering stabilizer, raised steering arm,
Rear end 12 bolt 373 gears with lock right locker and diff guard with 6 in skyjacker springs and off road design 1in level blocks
Heavy duty off road design front and rear shackles
Off road design heavy duty front shackle mounts
Poly bump stops front and rear
Quick disconnect front sway bar (off road design)
6 inch skyjacker front lift springs
New pro comp shocks front and rear
Braided brake lines front and rear
New radiator, New dual electric fans
New starter with remote selenoid, alternator , water pump, belts, spark plug wires, valve covers
*Brand new Tune Port Injection kit (all new kit $2500, not from scavenged parts)
Hooker competition headers and dual exhaust
Off road design engine crossmember and motor mounts
Borgeson steering shaft
Dual battery trays
York on board air compressor mounted, still needs to be wired and plumbed
Off road design steering brace and plate
New oil pan and aluminum trans pan
Trans temp and temp gauge
Poly transmission mounts and body mounts
New grant steering wheel
Rebuilt turbo 350 transmission
Rebuilt 205 transfer case with off road design twin stick shifters
Tach
Tilt steering column
In cab winch controls
Rear hitch
Front floor pans just replaced and rockers replaced
Have but needs to still be installed:
New body panels- LT & RT inner and outer quarters, Tailgate, rear body panel, rear floor pan, inner wheel wells,
Rock sliders
Brand new in the box Corbeau front bucket seats and rear Corbeau bench seat
Master craft 5 point seat belts brand new in the box (4 sets)
B&M floor shifter
The motor was rebuilt when I bought the blazer. I swapped the cam and lifters to a more aggressive set. The tune port injection makes it very nice for starting and driving and works great when offroading. I have owned this blazer for the past 13 or 14 years but have not put a lot of miles on it. Most of the work and parts have been done in the last few years. I have been threw this blazer front to back top to bottom. I also have more parts and 4x4 stuff that I can sell with it. I was planning on having it caged once the body was done. I hate to sell it but I just have too many projects and could use the money and room. I don't want to part it out, I want to sell it as a project with all the parts and pieces. I'm sure there is more stuff that I am forgetting. If interested give me a call or send me a text. I can possibly deliver after it is paid for if it's not too far away. I know the asking price sounds high but if you add things up it cost way more to buy it all not including the blazer. Asking 6,500 OBO Thanks Jason 720-308-7792
Installed it has:
Front tow hooks
Dual battery trays
Tach
Rear hitch
Rock sliders
B&M floor shifter
