Life and weather has impeded my progress but I did get another baby step tonight. I got my clutch/pressure plate bolted up.
I do have a question for the better informed. The two fuel lines shown in the pics, bottom line is supply, top line is return?
Thanks Larry, excuse my newbie ness. I thought that was the regulator and figured that meant return but this is my first FI swap rodeo.The return line has the regulator on it so the top is return and bottom is the supply
I am going to have to run new brake lines from the hydroboost to the proportioning valve because of the flare switch up. Anyone know if the lines going back will swap into a 1986 valve?
The MAW's and the While I'm Here's list is very long!
Because I do most things bassackwards!I’m confused on this…
What is this flare up you speak of? I’ve done a few hydroboost swaps and haven’t had to do anything with brake lines other than on the K10 where the front and rear lines had to be swapped at the master cylinder. Yours being late 70's truck will probably be like mine where you just swap the front and rear lines at the master providing you are using a master cylinder for the same year as your K5 but with hydroboost. For example, my truck is a 78 so I used a 78 1 ton w/hydroboost master cylinder. On my 89 Suburban I used an 89 Suburban with a 6.2 diesel master cylinder since the 6.2's all had hydroboost.
You can kinda see how the lines got swapped at the master cylinder on the K10 in this photo. The big line moves to the front on the larger master
That makes sense. As far as metric and SAE, it gets confusing…. Yeah, things like the hydrobooster, power steering pump and steering gearbox fittings went to metric (M16 and M18) in 1980 but the brake line fittings at the master cylinder and prop valve stayed SAE throughout all the square body years (except for possibly some oddball 90/91 half-tons with RWAL like Rob’s had) although the brake line fittings at the calipers went metric at some point (around 1985 I think) on everything as far as I have researched.Because I do most things bassackwards!
No here's the deal, the hydroboost I have already came from an 88 square and has what looks like a fairly new m/c, one of my factory brake lines has a hole rubbed in it from being pushed up against the steering. So I have to replace at least one of the lines already. So I figured replace the lines to match up to the m/c?
Side note: my foggy memory thinks metric fittings started in the early 80's?
More foggy stuff..... the blue fitting on your m/c.....metric? my 87 CC and my 88/67/69 shorty are both blue and I was thinking blue was a quick id of metric??
I have no problem dropping the coin for a new 77 hydroboost m/c but the number of returns I have been doing at work lately for craptastic [new] and reman parts lately has got me ready to pull my hair out! It SOMETIMES seems to be a good idea to use a proven but not used up piece.
As always you guys thoughts/ideas/head scratching is always appreciated.![]()
So that brings up another point. If your hydrobooster is from an 88 and assuming you are using a later model power steering pump on the L29 you’re going to need to also swap on a later metric steering box as you’re going to have a line incompatibility.
That looks like a factory piece. The font on it looks correct to the rest. Nice touch.That hand throttle setup is neat.
