Sounds like your issue may not be the carb. Could be ignition or valve timing or worse.77 Sub , Qjet. finally took a dump, 3 rebuild’s later from reputable mfg. & still junk. I got a Holley 4160 & can’t get it running ??
Something that in the fuel system?Sounds like your issue may not be the carb. Could be ignition or valve timing or worse.
Yes, pulled the new battery & it’s taken 2 days on charging to get to green, saw it before I left for work this morningSounds like your issue may not be the carb. Could be ignition or valve timing or worse.
"1st time I primed it thru carb it ran good, then died". How long did it run. 10 seconds or 10 minutes? If it ran, I doubt ignition problems. Does it start and run each time you prime it?. I bought a new battery-wow those prices jumped ! so I took it out , put on trickle charger it’s taken 2 days to go green. I’ve got fuel pressure regulator at 6 psi which Holley wants. With return line to fuel pump ? Or should I put it in line before pump ? Which is how I read diagram.
I just about didn't click the thread as it's all stated in the title...after clicking, it makes less senseI'm just slow clapping at the longest thread title I've ever seen here...
Carry on!
The 1st one I had mine rebuilt,but guy didn’t tell me throttle body was too worn out till after I reinstalled-thus big vacuum leak. I then bought remfg it ran for couple weeks ( don’t know how ) then just started flooding constantly,returned for another & it had same issue right outta box. So tired this crap & got a Holley. I have mechanical pump with in-line filter & regulator. I replaced cap,rotor,ignition module,coil, spark plugs & s.p. wires.So you bought 4 carbs? Or had yours rebuilt 3 times before the Holley? The definition of insanity is doing the same thing over and over and expecting different results…..
Yes it’s gas , & pump is putting out 7-9 psi . Qjet required no more than 5, & Holley requires 6. I looked everywhere for lower psi pump, couldn’t find one. Yes even after sitting for 3 days now bowls are full. It started &ran 10 seconds & hasn’t run since. Even with full charge on battery. Vacuum leak somewhere ??Why a regulator with a mechanical pump? Is it getting gas? Are the bowls full after cranking?
