78 Jimmy?
Oregon
Hi
I have a 78 Jimmy I blew transfer case chain right outta the side of. I’m wondering if I did something wrong for that to happen, I was given the Jimmy and it had hubs to lock in on the front? Looking and reading about them I see they were 4 wheel all the time so not sure why the locking hubs….
The transfer case chain gave up because its 48 years old. The locking hubs were put on to help increase gas mileage and reduce wear on the drivetrain. Sometimes the transfer case had a part time kit installed too.
Hi
I had the same thing happen to me 20 years ago, the chain broke and it bunched up between the gear and the case and broke out through the case.
Np203
As @HankScorpio mentioned lots of people put part time kits in them with locking hubs.
If you're just wanting to put it back the way it was the good news is that the np203 are a dime a dozen.
Yep. Throw another used 203 in it, or put a 208 in it. NP208 gives you a 30% lower low range, and you get to replace the rattling, noisy, sometimes is a pain to get in gear 203 shifter. LOL Downside, is you lose your low range/2wd mode.
He needs a different output shaft on his th350 to mate with the np208
