runamok151
1 ton status
Didn't you just swap that motor in? Must be a Jersey thing. hahaha
on supply line i put 2 clamps... on return just 1.I have return line on mine that's stainless braided with hose clamps, and I haven't had a problem on my 60psi system. Granted return line pressure is lower, but I think you'll be okay.
Umm, that's the oil pressure sender. Crank sensor is just below that and if I remember right the connector comes in from the side and not the top.
bwaahhahahaa I hope your right....lol that would b awesome...Umm, that's the oil pressure sender. Crank sensor is just below that and if I remember right the connector comes in from the side and not the top.
I'm pretty confident I am. There's only one terminal on the oil pressure sensor you pictured, not three that the crank sensor has. The shape and size of the sensor is the other dead giveaway.bwaahhahahaa I hope your right....lol that would b awesome...
thx.. yeah im good there...View attachment 375648Crank is yellow, oil is red. Orientation of crank sensor connector may be 90 degrees different.
Here's the chart I made while doing my swap. A couple of the commctors are different for 03+, like the oil pressure sender.View attachment 375650
