78 k5 6.5td swap questions
Discussion in '1982-Present GM Diesel' started by Head Trauma Johnny, Oct 13, 2017.
  1. GWeakland620
    GWeakland620 THE CK5 Crayon Eater Premium Member GMOTM Winner
    Sep 15, 2010
    10,616
    7,700
    Toe-peek-ugh, KS
    Build(s):
    3
    Pictures? :popcorn:
  2. Head Trauma Johnny
    Head Trauma Johnny Registered Member Premium Member
    Oct 12, 2017
    17
    15
    Will take some pictures throughout the swap. The 95 6.5 came with a.c. compressor so I want to keep that on my k5. What year of s10 (blazer or truck?) Do I need to look for to make room for the turbo.
  3. Head Trauma Johnny
    Oct 12, 2017
    17
    15
    So far I have finished pulling the 6.5 out of the the 3500, pressure washed the engine bay. Tomorrow I plan to swap the 2000 water pump with the better fan, replacing oil pan gasket, new timing chain, and rear main seal on the '95 6.5. Then stuff it into the 3500. When all said and done I will do a complete rebuild of the 2000 motor to swap in the k5.
  4. GWeakland620
    Sep 15, 2010
    10,616
    7,700
    Toe-peek-ugh, KS
    Build(s):
    3
    Cool stuff!
  5. Truckman4life
    Truckman4life 3/4 Ton Status Premium Member
    Feb 17, 2010
    1,915
    1,766
    Rigby, ID
    Build(s):
    4
  6. GWeakland620
    Sep 15, 2010
    10,616
    7,700
    Toe-peek-ugh, KS
    Build(s):
    3
  7. Head Trauma Johnny
    Oct 12, 2017
    17
    15
    Sorry guys it's been slow progress. Finally got the 95 engine in the truck and all the differences in bracketry figured out. Put fluids in today and finally started it. Now I just have to button up a few things tomorrow and get the truck sold. Then on to ordering parts to rebuild the 2000 to put in the k5. Will take a few pics along the way and post.
    Truckman4life and GWeakland620 like this.
  8. Head Trauma Johnny
    Oct 12, 2017
    17
    15
    Ran into a few issues with the serpentine belt not running centered on the tensioner pulley and took awhile to figure out. Once I did, I started it up and took it for a test drive. I have a couple of coolant leaks and a couple of gauges not working but overall I'm glad it's up an running. I have to change out the heater core next and get it on Craigslist.
    anyone on here interested in buying a newer IP off the 2000. I would like to get 350 to go towards the core charge for the mechanical IP.
  9. Head Trauma Johnny
    Oct 12, 2017
    17
    15
    So I finally got the 3500 home today. It still needed few things to get done. One was the heater core which took about 30mins and the other was removing all the hack job wiring, which was a lot. Also one of the front tires had a flat spot on it so I replaced it with one I had lying around. Left on the to do list is to find a few dash panels that are missing and replace 2 wheel studs on the front passenger tire. Things are coming along nicely and the more I do to the truck the more I want to keep it.
  10. Truckman4life
    Feb 17, 2010
    1,915
    1,766
    Rigby, ID
    Build(s):
    4
    Yep the 95-00 are pretty nice with the newer dash. @GWeakland620 truck is pretty sweet in person with the solid axle and lift it has.
    max 02 and GWeakland620 like this.
  11. Head Trauma Johnny
    Oct 12, 2017
    17
    15
    Well I topped off the dex cool this morning and then started the truck. After about 30 seconds it just shut off, then it started right up and shut off a few seconds later again. Kept doing this. New to the 6.5s is it a bad pmd? Thanks for any info.
  12. campfire
    campfire Adventure is out there! Premium Member
    Jun 7, 2013
    19,950
    8,980
    Northwoods Wisconsin / da U.P.
    Build(s):
    3
    Sounds like it. Air bubbles in the fuel line will also cause stalling, but it will also include stumbling as the air bubble passes. So I'd look at the PMD, especially if it's still mounted to the injection pump. Turns out that was a terrible place to put it. Even on @GWeakland620's truck.
    A random wiring fault is less likely, but would also cause it to abruptly stop.
  13. GWeakland620
    Sep 15, 2010
    10,616
    7,700
    Toe-peek-ugh, KS
    Build(s):
    3
    Yep, check to see if the PMD is still under the intake. If it is, start there. Cheaper than a new pump, and would eventually fail anyways.
  14. Head Trauma Johnny
    Oct 12, 2017
    17
    15
    Yeah the 95 and 2000 both had the pmd relocated. Plugged in the 2000 pmd and started it up and let it run for about 10 minutes. Hopefully that was it. Would suck to replace the IP when I already had it apart and could of replaced it easily. Thanks for the help.
    Big Ray and GWeakland620 like this.
  15. Head Trauma Johnny
    Oct 12, 2017
    17
    15
    Do you guys know of a reputable machine shop in Colorado to hot tank, inspect, and bore the 6.5 block? Also to do a rebuild on the heads.
  16. GWeakland620
    Sep 15, 2010
    10,616
    7,700
    Toe-peek-ugh, KS
    Build(s):
    3
    I'm out on that one LOL.
  17. Head Trauma Johnny
    Oct 12, 2017
    17
    15
    Took the heads off tonight. Found the culprit of the blown head gasket. Looked at the heads and cylinder walls and everything looks good. still has good hatching on the walls so I might just re-ring it, put new bearings in and freshen up the heads and call it good. Going clean up the heads in the parts washer and take the oil pan off tomorrow.
    Truckman4life likes this.
  18. max 02
    max 02 N.E.D. Premium Member
    Sep 29, 2009
    9,005
    1,841
    Clive Alberta Canada
    Build(s):
    Nice! I want to watch. :popcorn:
