78 questions
k20
My 79 K20, Camper Special 8400GVW has a 10blt front, 14blt rear, 4.10 ratio
78 questions, that's a lot!
Check what the front axle looks likes, perfectly round differential, 10 bolt, otherwise D44
Check the glovebox sticker for gears
mudslinger6 said:
a 78 3/4 ton 4x4 with all time 4x4 tranny would that have a dana 44 up front???and whats the stock gears in that???
78 was the last year for the dana 44 up front. the most common gear is a 4:10.
i had a 78 blazer that had a 10 bolt. from what i have found it can be either 10b or d44 for 78 and 79. in a 3/4 ton i would guess 4.10
Dana 44
Corp 10
speedyvision917 said:
also, does anyone know about all wheel drive for that year?
If the front axle was Full time 4wd, then it would have full time lockouts. And the 203 tcase would of been fulltime. The full time lockouts look like this:
Top pic is off a 3/4ton and the bottom pic is off a 1/2ton
A Dana 44 was available up until the very early eighty's - although most came with a 10 bolt front since 1977 .
Tom
