CGT80
Someone asked if I was going to do a build thread on painting my engine bay. I guess I might as well. This project has been like Greg's "might as well" project, and I refereed to it as that even before I saw his thread the other night. The thing is, this is my daily driver and I don't want it to be down any longer than it has to. I have my 88 K5 with 35's and a 6" lift to get me around right now. That one might get a build thread, but it isn't nearly as special as my C20.
My dad gave me the C20 when I turned 16. He bought it used, when I was four years old. I probably recognized that truck better, as a little kid, than my own pecker. We did everything in it. Camping with a boat and slide in camper, went to the shooting range many times, to the dumps, to the home construction stores, Sea World when I was very small. I rode in the camper shell on the Sea World trip (2 hours or so from home) and used a seat belt that my dad put in just for me.
The truck has been my do it all as well. I learned to drive in it and also my uncle's 93 Chevy 1500 short bed v6 picup. I drove it to school, community college, drove it to work when I was a painter for my uncle, used it for my side jobs, then got another job doing construction and property management and decked it out for that. I got a dirt bike and then a toy hauler and this truck drags around the toy hauler that weighs in at 8k pounds without the toys.
I have done many upgrades already, but will share some and the current work. Some specs:
79 C20 Camper Special 8200 GVW
It has always had 31's on the front and 33's on the rear.
I have BFG all terains and 16 and 16.5" pacer directional chrome wheels
stock height
had a sbc 350/th400/4.10 open diff.
In 2003 I had the rebuilt POS 350 turned into a 383 and added edelbrock heads, intake, water pump, and valve covers, MSD HEI, Douge Thorley tri y headers, 3" cat, 3" single pipe with 50 flowmaster, then later 40 series, then finally the super 44.
I ditched air shocks for rancho in cab adjustable shocks and I added 5k pound air bags and an on board air compressor to level loads. Now I run non adjustable gas shocks on the front. They were changed with the upper ball joints.
The other front end components were changed and aligned a couple years ago.
The 14bff has discs with 3/4 ton 4x4 front calipers and hoses that also fit the front of this 2wd truck. The rotors are powerslot, but the ones on the front are cryogenically treated. All pads are Hawk HPS. The master and front calipers are part of the original JB7 brake system. It is a one legger and the 406 will break it loose very easy on a bad surface. Good road surfaces are a bit harder to do a burn out on. It also needs a bigger carb to reach its full potential.
The trans has been rebuilt my my uncles shop. He only has one employee and they have worked together for decades. It has a 34 element sprag and good drum, along with a bunch of other goodies. It had a -2 transgo shift re-programer last time, but it was toned down a bit this time. The trans is sitting on his bench waiting to go back in the truck. The shift was very hard from 1st to 2nd. I had them bump it up from their usual firm shift. The torque converter is a TC 275 with anti balloon plate. It was used in early Allison transmissions and is the toughest converter for RV/street use in a Th400, according to my uncle. It has a secondary trans cooler.
My brother and I added the Gear Vendors overdrive unit. I have a 3 speed auto with a 2 speed hybrid behind it, and it gives me 6 gears forward. I can only use direct drive when engine braking, so 2nd direct is used down grades.
. It is a bit higher, but I love how easy it is to see over the wheel. I am only 5'7" and I like to sit high and not layed back. I will have to get a photo when the interior is back together.
. My starter had been grinding for a year or more. The engine was only two years old with 27k on it. I thought it was the shims, or just miss match in parts due to a different block. It rubbed when I got on the loud pedal, but not at an idle or cruising. I had to grind relief into the starter gear. My uncle knew about it, but it didn't dawn on him. He said it could be from a mix of high performance parts and a mini starter. My clearance looked good when the starter was bolted up.
this is what I think of my luck.
