79 GMC K3500 Crew Cab
1967k10
Nebraska looking for D60's
79 GMC Serria Grande 3500 crew cab SRW. 454/th400/203, D60/14bolt, 4.10 gears,ect. Has some rust in the rockers and in the wheel wells but it strait. Minimal dents if any. Needs cleaned up a bit inside but interior isn't bad. Needs dash pad and front seat on drivers side is ripped.
T-Case has a hole in the rear half. Be easy enough to get a rear someone discarded from a doubler to fix or just put a doubler in this and make a crew cab truggy :D.
Will have pic's up shortly.
$2250
Edit: There is one dent in front right fender and one in the right rear cab corner up high.
I've got a title right here :D. VIN says tkr349b510418
203 shouldn't been there unless it was a 77 or 78.
Well, according to the LMC catalog and their VIN decoding, this truck is a '79, not an '80.
T... doesn't say what this is
K... 4 wheel drive
R... 400 engine
3... 30/3500
4... pickup
9... 1979 year
B... Baltimore
Rest of the numbers are the build sequence.
The 203 is normal for '79 years.
the T in the vin number means GMC.
Do you have any more pictures? Is all of the A/C system still there? Pictures of the broken NP203? Does the engine run?
Martin
Tell me what you want to see and I'll get more pic's. I'll shoot a couple shots of the T-Case. The fuel pump seems bad and I'm going to replace it and it should run good. Sounds really good when it runs but only stays running for 30sec. Basically as long as there's fuel in the line between carb and pump. I've been filling it,then hooking to carb and it will run that way.
A/C system appears complete.
Martin
Oh, I am just trying to see what is all there, and what isn't. I am trying to justify buying a third K30 3+3. I regret selling my first one, but I still have the second one. I think if I did buy it, I would probably part it out. My 1988 V10 Suburban only has a Dana 44, and I would like to swap a Dana 60 under it. THe axle i put under it have 4.10's, so I wouldn't have to do anything with the 14 bolt full floater I put in the rear.
Did you see that Craigslist link I gave you for the Dana 60 in Plainview?
Martin
