T
tenderfoot
Guest
If there is a part time kit in the 203 you'll drive in Hi with the hubs unlocked. The guy should be able to tell you.
Glad you found a good one. I would have looked seriously at the big block 5 speed truck if the drivetrain was solid. Sheet metal is really easy to swap. A solid drivetrain is the hardest thing to get.
I always think the other way around...but I also agree with you too. Depends on where you live I guess?
I have tons of square bodies around here. TONS. Good sheet metal is easy to get.
Tinkerin around replacing batteries & pumps and what not. Your being very selfish. We need pics man
Solid truck. Driver side cab corner has a little rust, back of the wheel wells in the bed are rusted through and there's a quarter size piece of rust near the back of the bed in the floor.Sweet, looks solid. How's the rust? So I was wrong, it is a 203? Does it have a part time kit?
Anyone kniw what could be causing this? Gear oil coming out of the breather and getting all over the place.
Lots of slimy crud around the pinion support in the 14bff
Too much fluid and a bad pinion support gasket?
Is there fluid coming out of the breather or you asking if that could be what is happening.Anyone kniw what could be causing this? Gear oil coming out of the breather and getting all over the place.
LOL...that's what I'm talking about. 5.00 seal or 700.0 locker, Meh, screw it......BwahahahahahaaaThat's a pinion seal leak. Bad fluid will bubble up and expand and maybe over flow. Better take it apart and put a Detroit in it to be sure it's ok.
Breather has fluid coming out.Is there fluid coming out of the breather or you asking if that could be what is happening.
I want to say looks like pinion seal is leaking but if the breather is puking it's overfilled or water got in
