The Shop Truck
Today I installed some electric cutouts. I was going to do like @ktmoutfront did and just use a switch to activate them, but the ones I got are 3 wire, positive, ground, and signal. I'm not sure what kind of signal it needs, but it is power open and close so it's 2 different signals. I liked the form factor of this one better than the style that have the 3 bolt flange. It just welds inline.
This will also make it easy to pull them out and cap off the exhaust if they fail.
The big Magnaflow mufflers I installed are pretty impressive. They're "straight through" but they split into 2 2.5" perforated pipes internally and merge back for the exit. The small ones in this picture are before the dumps, the big ones are after.
Driving it around you can decide whether you want to hear the blower whine or the exhaust, but you can't hear both at the same time :D.
Mine are 2 wire with a controller in the dash. I had to figure out how to switch the controller without the hated remote fob.
I did pull the box apart, it's a very simple board, but I'm not sure how I would trigger it with a switch. It has the 2 key fobs and a wireless button that I stuck on my center console.
Always wanted cut outs but wanted them vacuum operated. Something where they open based more on load than anything else.
They make these in a vacuum controlled version. I don't think my engine would ever make enough vacuum to shut them other than on decel.
My original plan was to control them with the Dominator. Open on startup for a couple seconds like modern factory hot rods and automatically open at 80% throttle.
They do make another version of the motor for the ones I got, but it requires a 3 way switch and was 2 weeks out when I ordered the kit I got, I didn't realize at the time that the motors were different though.
I like the idea for a set of switched ones. Pull up to a traffic light some want to be hot rod pulls up next to you, you flick a switch scare the crap out of them.
Freiburger just announced dates for Duct Tape Drags and opened registration. It's at Firebird Motorsports Park in Chandler this year rather than in Tucson. We're registered!
In other news, someone pointed out to my wife that the shop truck is in the Firebird Midnight Drags Facebook post. It's at the beginning of the video, so you don't have to watch the whole thing. https://www.facebook.com/reel/1023187963534058
We drove out to Glendale today to pick up the new fans from Ron Davis. The Spal fans are significantly different than the DeltaPAG fans.
A few things to note in the first picture is the location of the brushless controller (on the motor of the Spal vs mounted below the fan on the DeltaPAG), the beef of the fan cage, and the design of the fan blade (7 wide blades vs 9 thin blades).
Now if you look at the profile of the blades, the DeltaPAG blades are very steep and pretty much flat, where the Spal blades use the extra width to start shallow and pitch up at the back of the blade.
The final difference is the size of the wiring coming in to the fan. It looks like the Spal has 10ga and the DeltaPAG has 12ga.
I have no doubt that if you bolted these fans to the end of a tube, the DeltaPAG would flow more air, but if there is ANY restriction, the Spal is going to push through it easier.
Now I have some boxes to return the DeltaPAG fans in.
