I tried the alt and gave up. I even tried the inner fender well but the supply hose was too much of an angle. Per PSC they want it right over the pump. They DIY4x4 shock towers are nice if you want to relocate the shocks.@BattleBornK5 that's a great pic, thanks! I was hoping you had built off of the alternator bracket, I want to put a reservoir in that same area but I don't have anything to work off of except for the alternator bracket but even that is only 1 bolt.
No pulling of the instrument panel needed. I have it plumbed through the 2 bolt holes fore the old park brake mount bracket. I also plumbed it to my front brakes so I can modulate rear brakes with my brake pedal when doing a front dig. Sounds good in theoryI have some Ford shock towers I may use but I haven't quite figured the mounting location out yet, the Diy4x shock towers do look convenient.
The Parker valve by your headlight switch, is that for your brakes? I have one I'm going to plumb in to my brakes at some point but was wondering if it might make pulling the instrument bezel a PITA, I was thinking of using braided hoses with a loop for slack.
And I have ford shock towers also but diy made is much nicer to get around the steering shaft.I have some Ford shock towers I may use but I haven't quite figured the mounting location out yet, the Diy4x shock towers do look convenient.
