Alright, some of you know that I have a crew cab V3500 that I swapped an 8.1 into. Some know I've had some issues with start up, so I wanted to start a thread here in the garage section since not everyone looks at every thread in the driveway. Even though the 8.1 is technically not an LS, as far as the wiring goes its the same as a 5.3/6.0 swap. So here is what I'm dealing with:
I ordered a brand new stand alone harness from Howell Development along with a tune on the computer from them too (the same tune as most others have used doing the same exact swap as me). I replaced the crank and cam sensors on the motor cause these are very prone to failure in the 8.1 and real pain to change with the motor in the truck. Right now the motor will crank and crank forever without firing. I have confirmed I have ~58psi of fuel and the fuel rails, so fuel is not the issue. I narrowed down that each coil pack is getting power to them and the grounds seem fine (this new harness has all the grounds for the computer come together to one point, I have this bolted to one of the studs off the intake that normally the plastic cover would be bolted to...this is aluminum so it should be a good conductor), however each coil pack is not receiving the fire signal from the computer. I have found my 12v switched wire we spliced into for the harness (we spliced to the original wire that went to the ignition coil of the TBI motor as per instructed) has 12v's when the key is on, but as soon as I start cranking it drops to below 9v's. According to my understanding this wire is the power source the computer gets to send the signal to each coil to fire. I replaced the battery with an Optima Red Top, and that hasn't done anything.
Is there anyone else here with LS swap experience that has dealt with this before? Where else could I be loosing the cranking amps that would cause this issue. I'm not an electrical guru by any means, but I have felt like I've checked the majority of the basics and can't seem to figure it out. Any help would be appreciated!
Thanks!
Thanks!
. But if I posted everything I checked over the last month and a half, the original post would be a novel, haha.
