I have a 1979 Chevy k30 I’m wanting to swap the 350small block for an 8.1l vortec. I’m going to use the sm465/np205 thats already in the k30. After reading the forums it sounds like using the sm465 is pretty simple. Use the 8.1 flywheel and throw out bearing. Flywheel bolts are metric. Are the bellhousing bolts metric?
Recently read this article and it says “Swapping 8100s into classic Chevys with manual transmissions requires a hydraulic clutch actuator. The 8100 block lacks the threaded receptacle for clutch pivot ball.”
Can anyone confirm if the mechanical clutch linkage does or doesn’t work with the 8.1l vortec? Thanks
