8 Low
They're about a 40...
And they'd run you about 6-7 grand lol
I was looking at replacing my 42's and the best bang for the buck that I came across was 40" LTB's. I hate to downsize but 42's are expensive.
Well, I've been working but it does not seem like I have made great progress. I have had the fuel tank in & out a dozen times trying to get my crossmembers just right. Getting the 32 gal tank in just the right spot between the center section & the rear shackles was a pain. Had to cut up one of the pickup box crossmembers for clearance on the top. Fuel lines should be a go. Finally got the right rear spring bushings so the rearend is bolted in again,,,, for the 3rd or 4th time. I do not like the angle of the shackles but I will see how they look after I drive it a bit & get all the weight in it.
Hydro assist, tie rod, brake lines & such are here so I have work to do. I have the Hydro brakes out of Big Yellow & need to install them at the same time as the Hydro assist steering. I'm getting pretty damn close to being able to drive this pig. I need to. I'm starting to get tired of no sleep with no rewards. Once it's driving, future upgrades will not be so bad. The kid & I put a wrap on his crawler last night. Both of our mini crawlers are acting up. Going to have to tear into them too.
What's the skinny on shock placement? I see guys using Ford towers in the front but why? Just to get the angle more in line with the movement of the axle? I'm going to build a crossmember for the rear shocks. Do you guys ever run them outboard of the frame? Looks like I'd have just enough room if I modified my spring perch with a shock stud. Also I'm thinking I will run the eyes in opposing directions in the rear. Any reason not to?
Stupid FN snowball! I swear I plan my whole life around hiding boxes that keep showing up at my house. Sometimes I have to tell her we need milk just so I can beat her home. I've sold everything I own at a loss just to feed this pig parts & it still wants more!
MightAsWell is a ruthless master. :deal:
