80 K5 Blazer in TX
Quackaddict
Glenn Heights, Texas
Well I put a whole lot of work into it but some situations have come up so it is back for sale.
1980
Chevrolet
K-5 Blazer 4X4
5.7 350 V8 (rebuilt 3 years ago less than 10K on it with cam upgrade)fresh oil change, plugs and air filter, breathers, valve covers
TH-350 3 speed auto tranny, fresh fluids
New parts & Upgrades
NEW battery
NEW Alternator
NEW Starter
3/4 ton Axle Conversions (14bolt Semi-Floater rear w/ Gov-Loc 10 bolt up front) 4:10 gears and fresh fluid (Lucas HD oil)
NEW 6" Rough Country lift (springs in front block and AAL in rear)
NEW Extended brake lines
NEW Off Road Design 1" Zero Rate in rear
NEW 16.5 X 9.75 black Rockcrawler wheels
Used 36/12.5/16.5 Goodyear Wrangle RT II tires
NEW U-joint in rear
NEW Windshield
NEW Belts
NEW Steering Wheel
***NEW skull T-case shifter and 8 Ball Gear shift knob***
Bad
Need extended driveshafts
Speedometer doesn't work
fuel gauge is touch and go
E-brake needs to be hooked up
Interior is very rough ( I haven't gotten to this yet)
brakes need to be bled again (pads and rotors are still very good)
Hood needs replacing.
I have the replacement back glass but needs new motor before it can be put in.
I have receipts for all of the new parts as well as log showing everything I have done to this to include part #'s for new parts so you don't have to go searching. Just registered this month as well as saftey inspection. Runs good sounds mean (glasspacks). I painted it black myself did an ok job tough paint job should work very well just not perfect. I have been driving it a lot lately. It has just come down to selling this or having the electricity turned off.
$2200 very good price for all the work already done.
P.S. I have the rest of the trim pieces just have not put them on yet.
