Been pretty busy lately so I haven't made much progress.
I did decide one of the best ways to get more clearance in my steering, for the hydraulic system, was to get rid of the overly long cylinder. This cylinder was originally meant for a low steer set up on my old crew cab. I have no other real purpose for it and have been messing around with internal stops and yada yada.
Here's a couple shots of the modifications so far.
The length of the ram was shortened up just a little less than 3", however, the ram was drilled and tapped at that length making the ram itself around 5.5" shorter. That being said, I will modify the casing yet, it will also get a little less than 3" shorter. So, with the ram fully extended, it will be 8.25" shorter than it was originally. Full extension is where I was coming up with the most clearance issues. Ram side of the cylinder was reaching out over top of the leaf spring and getting very close to the ubolts and ubolt nuts.
I measured my high steer drag link travel at 5-3/16". The ram is now set up for 5-1/16" of travel leaving the cylinder itself to be the steering stops.
So, next step is to shorten the casing. Gona cut the tail off of that today. Much easier to modify the tail. Not a lot going on back there. Machine up a new end cap and port for it and get it all welded back together. The new port will be welded on behind the casing itself so there will be no concern of warping the tube where the piston travels.
