ngoetz
Registered Member
I bought a 81 blazer in the end of May. I was gone for the month of June in Germany so now i am back in the states trying to sort out issues with the K5. The truck has about 8 inch of lift and 37" SSR with a rebuild 305 and th350.
It has a radiator from a 90 suburban if that makes a difference (not sure if the suburban radiator is bigger) But anyways the temp gauge never goes above the first mark on the temp gauge. The is no fan shroud on the radiator so i would expect it to have problems cooling but it doesn't raise above the first mark under any circumstance. Does anybody know how to test the coolant temperature sensor?
