I'm not sure what area you are talking about? These help? I do remember Robs was a bit different than mine from the factory.Can anyone confirm the location of the pass through / where to bolt the piece of topper to the camper front wall?
I forgot to measure the location of the original. I would assume it is flush but bottom of the camper sides and centered left to right?
That was a process. It required the truck to fit. The basic rundown was we fit the front wall to the camper with the opening rough cut smaller so we had material to cut back to fit. The camper was set in place to the truck with the front wall butted up to the cab. We traced the size of the opening to the wood. We then slid the camper back and cut the opening to size with a hand jigsaw.Can anyone confirm the location of the pass through / where to bolt the piece of topper to the camper front wall?
I pretty much did mine the same way.That was a process. It required the truck to fit. The basic rundown was we fit the front wall to the camper with the opening rough cut smaller so we had material to cut back to fit. The camper was set in place to the truck with the front wall butted up to the cab. We traced the size of the opening to the wood. We then slid the camper back and cut the opening to size with a hand jigsaw.
At the same time, we had the section of the top in place and traced its shape out to know where it was going to land on the wood also. You can see the trace in the pic above.
With the camper pulled back we were able to locate where the top section would sit and screwed it to the front wall. That gave us the ability to drill the holes through from the front for the bolts to lock the camper to the cab.
I can get measurements off of mine if you need them, but the most accurate way to size/locate the pass-through is to fit it on the truck.
You are right in that our were different to start with. But in general, FWC made the opening asymmetric.
Mainly to house the icebox or 3-way fridge behind the driver seat. I wanted the opening to match the cab. I wasn't going to run the fridge there so I could have more space for my seat. Ironicly now that I have the 5-speed in the truck I've found I can't drive with the seat all the way back like I did with the automatic. I can't reach the bottom of the stroke of the clutch pedal with it back!
It looked like an ordeal. If you could check to see if it ended up centered I would really appreciate it. I am basically working on this alone 99% of the time so on off, on off, test fitting is trying to be avoided as much as possible. I guess I will follow suit and rough cut it in.
I am to the point of setting up the counter and cabinets and am trying to get a closer idea as to the fitup with the opening like you guys have them. As I also plan to remove the fridge (mine was just an ice box anyways).
Yikes. Your door looks worse off than mine does. I know mine is a little wobbly and the wood is probably weak like yours.
I've looked at a couple of threads on WTW that have rebuilt the doors on the older FWC units. I don't know of any source for the aluminum extrusions they used. Most reused what they had and rebuilt the rotten wood with pressure-treated lumber cut to size. It's probably the route I'll take when I get the courage to take my door apart.
Did ATC say how they would build the door? Wood again or Aluminum?Well, crap. ATC said all they can do is build me a new door.
Have not heard back from Dexter Door yet but with the holidays it's not surprising.
At this point it's 475+ shipping for a new door. Plus the cost of aluminum sheets, insulation that I already have purchased to repair / rebuild the door.
Unfortunately, my windows will not match at that point either. The new door will have the new style rounded windows and all the others will be original.
Debating buying an ACDC TIG and wasting a bunch of time repairing the original trim
