81 K5.. AKA Fingleress's POV.... Transmission IS in!
Well Transmission is IN.... Finally.
Also replace the Mounts in the transmission with new poly ones while I had it out. Shifter looks good and Functions well. The Neutral Safety Switch was a PITA!!!!
Now a Question. When Selecting Gears it seems to CHUNK into Reverse and Drive when going from park or neutral. This is While sitting Still. Anything I should Check?
I hope it's not the trans, I just replaced it. Guess I'll swap u joints first and go on from there.
