Price Drop 81 k5. "BlaZeus". $6500
BlaZeus
The Real Mateo
Sheridan, WY
Offer on a house was accepted so time to sell the toys. Asking for $9k OBO. Located in San Luis Obispo, CA.
Started out as a stock 81 k5. Lots of work, time and money has been put into this build over the past 2 years. Built to be able to haul ass out in the desert and then crawl over rocks in the mountains.
Crate SBC 350, less than 5,000 miles. Have receipts.
Edelbrock 1406 carb, off road tuned with off road needle and seat kit installed, has never stalled out while climbing.
New 3" aluminum radiator and thermostat, dual HO electric fans with shroud, new electric fuel pump, new in line fuel pressure regulator.
Turbo 350 with Art Carr Winters sidewinder shifter, Np208 transfer case
Custom, long travel drive shafts
HD Dana 44 front, 4.88's, open
14b ff rear, 4.88's, Detroit locker, armored diff cover, truss'd
3 link front strapped at 16" travel, radius arms and panhard, 14" King dual rate coilovers with reservoirs, beef heim crossover steering, new power steering pump and gear box.
4 link heim rear strapped at 20" travel, short course style setup with 14" Bilstein dual rate coilovers with reservoirs mounted off axle.
Disc brakes front and rear, new stainless steel braided lines, new front calipers
Full 1 ¾" caged front to back with 1 ½" & 1" tube reinforcements. Engine cage with removable cross brace supports, frame backhalved and new high clearance boxed frame made with 3/16" rectangular tubing, high clearance engine crossmember, plated shock mounts front and rear, custom steering box mount with cross member support.
Custom aluminum dash and center console, Autometer gauges, kill switch, all functions on switches with push button start, 4wd shift linkage relocated closer to driver for accessibility in harness.
PRP suspension seats with 6 point 3" camlock harnesses. Have seat sliders if wanted to mount seats to floor instead of cage.
One of a kind, custom full fiberglass front clip 07+ Chevy Silverado front end conversion with halo HID blacked out headlights.
Tube prerunner Baja style bumper with skid plate.
52" cherry red roof mounted curved LED light bar.
CB radio and antenna.
New windshield with new moulding.
Removable hard top with solid windows.
17" pro comp aluminum wheels wrapped with 39" BFG Baja KR2 race tires with full size matching spare.
22 gal fuel cell
High capacity bmw battery mounted in back with quick disconnect.
Lots more. This truck drives straight and comfortable on the freeway at 70 mph and then can haul ass out at the dunes. Gets tons of attention and people driving by giving thumbs up. Not interested in trades. Clean title. Call or text if serious. 7606nine62one00
Bump.
Well...little problem. Where the panhard frame mount bracket is, the frame got all jacked up from jumping it and railing on it on the desert trip. I have no way to fix it in my current living situation so basically I'll take $6500 for the truck. I could easily part it out for that much for sure but would rather sell it to someone who has the means and abilities and time to do it right and fix the small frame section. I'm taking a huge hit on this and I'm really bummed but I just can't fix it and there's not a shop around me that would let me work on it. I also would hate to part it out and see all the work I did putting this truck together go down the drain but I have to move on with my life. will post pics of the damage later today.
