BlaZeus
The Real Mateo
Just got done with my rear axle swap and 4 link suspension and found my rear drive shaft is too short by like 1/2". It barely hangs off the end output shaft of the tc at ride height. Called local drive line shop and said he doesn't wanna extend it and a new one will be $400. Def not paying that; so does anyone know if a drive shaft from a c/k10 with the same tc and yoke splines will fit or should I try and get it extended by 3"-4"? Thanks!
