82 c10 stock gears?
1BadK-30
Phoenix, Arizona
i know its a shot in the dark but does anyone know? i search and found a bit that it could be 3.08's and 3.73.
One '82 K-10 I have has 2.73........yes.....special ordered!!! It would not back up a steep hill with the stock 305, unless I put it 4L...........wow, what was someone thinkin'?
OK its easy.
jack it up, get a drain pan.
undo the 10 13 mil bolts around the cover
Get a scraper and hammer, pop the cover off
count the teeth on the ring gear and the teeth on the pinion
divide ring by pinion= ratio
clean the gasket off, silicone, bolt the cover back on and filler back up
You could guesstimate by seeing how many times the pinion/driveshaft turns for one revolution of the tire.
yes i know i wont get the exact gear ratio correct, but frankly i would rather not mess with it.
this thread is going nowhere. was a silly question to ask when there is common ratios it could be.
There's nothing wrong with asking it, yes it could be one of 4 or so ratios STOCK, but could be any number if ever replaced, which is entirely possible.
Most (like myself) recommend pulling the cover because not only will you know exactly what's in there (gears, as well as limited slip, etc) but you will then know it's general condition, and you know you have the correct amount and type of fluid to make sure it continues to work the way it should.
