Or go roadkill with a Rubbermaid tub and a small pond pump from the garden center
I'm thinking of this route as I have extra tubs sitting around.
Do you have lots of fine metal in the oil or just the coolant? I have built a ton of semi truck engines with hydraulic lifters and never had issues with contamination in them but they do have lots bigger oil systems to disperse any leftover stuff into after the new engine is built. I guess if they are cheap then it's good insurance to replace them. Cummins used to sell a really good solvent by the gallon. Not sure how expensive it was though. The Cummins warranty guys at the dealer always wanted it to wash down their rebuilds so they didn't have to use the dirty parts washers.
That’s puuuurrrrddddyyyyy!!!!!![]()
Once it's all buttoned up, I'll throw some paint on it.
.Would they be any different than my oil cooler lines on my 6.5?Since I just thought of it while in your thread. Do you know anything about swapping my 6.2 oil cooler hoses over to either hyd hoses or braided stainless ones? I have access to making hyd hoses at work so that would be a good route to go but I just haven't checked into the fittings at the block end or if they will easily adapt to the oil cooler end. Just though I'd ask. Thanks
No fancy paintjob?
