Ah, time for an update. The last 8 months have been crazy. Work has been slammed since early spring and hasn’t let up. Which is good as it lets me buy parts as needed.
A whole list of things have happened and been done.
So first the oil pressure issue is not an issue. I made a “T” off of the oil pressure port from the stock position. So stock gauge and the same cheapy mechanical gauge. Results, 60lbs at cold idle. 10lbs hot idle. That’s with the oil at 170~180 degrees. Pressure goes up to 30~40 range when cruising. So pressure is good.
Turbo issue. The hx40 ended up having a 19cm2 housing not the 16 that I thought it had. Since finding a 14 for a hx40 was looking like it would be an expensive avenue. I took another route. Andy (@AugustDiesel) happened to pick up a lot of 4 hx35s. A few texts and calls and a gently used hx35 with a 14 housing was on its way to me. It required making some adjustments to the down pipe. But the cost was still way under parts for the hx40. The verdict, it works great and the truck runs very good with it. The 40 will probably find a home on the low compression motor when I get to building that one. For now it sits in a box waiting for that day.
The fuel system. So I pretty much ended replacing all of it. New tank, new lift pump, new lines and a new pressure gauge. The gauge I had was being affected by the heat in the engine compartment, causing a host of false readings. New gauge has a little port to adjust the internal pressure so you get a good reading.
I made up a quick little bracket out of stainless to hold the gauge in place. Bolts on the firewall where the stock water separater used to mount. The old stock lines were rusting so a replacement was in order. Well the lift pump I bought came with all new lines.
A fass unit that’s actually for a first generation duramax. Price, not cheap. Peace of mind, priceless. This will feed a dead constant 10psi and be stupid quiet will doing it. I also replaced the plastic tank I had as it constantly leaked around the sending unit. So a new metal one from Summit filled the void.
More to come.
More to come.
. That was something that had to be addressed sooner then later and of course they don’t make the same tire anymore. So a couple weeks ago I bought some Cooper discoverer sst in 315-70r17 fashion. I haven’t gone in the dirt with them yet but street manners have been very good so far. They’ve been good in th rain too.
. We did a 120 mile round trip the other weekend with the truck. A/c on and cruised at 75. Went dead straight down the road. I can’t complain one bit.
But both of those are significantly longer wheelbase than what he's running.
