83 Bedside Replacement
movario
Registered Member
Switzerland
Hi
As my rusty K5 is way more work than anticipated, I'm thinking of save some time and work and replace the whole bedside. At first, I wanted to patch it, but I've read that the bedside is basically a bolt on replacement.
So is it true that I just have to drill out the spotwelds on the B-Pillar and the rest are just bolts?
Ok, that seems doable.
I'm considering the LMC complete bedside.
If I can do it, anyone can. I've currently got one side off and one side on so lmk if you need pics of something. Mines a 73 so some differences but mostly the same I think. And from what I have heard, all suppliers sell basically the same product
That's right you got the new reproduction sides right? How do they fit ? How's the overall quality? Are they alot thinner than factory panels?
I still have to put the body back on the frame, cut out the brace and put the door on to tell. They are a few thousand in. thinner. I put the measurements on one of the other panel threads in the body shop
So today I took a closer look. Could you show some pictures where the bedside is attached to the rest of the body? Because at least the driver side is very rusty and would need a lot of patching anyways, so a complete replacement would probably save me a lot of work. But I dont want to drill out 15315355 spot welds in weird places.
The ones in the back are more like lap welds than spot welds and I just used a cutting wheel for these. Not pictured are two more identical ones on the other side of that c channel like rear bed support
So you're proposing to swap the entire inner/outer bedside with wheel liner as a unit? Maybe that's easier than doing just the outer bedside, especially if you have a clean donor. If you're buying all of the parts new I think it close to $2k.
Yessir, my inner fender was so far gone there was nothing to weld an arch panel to. Also the upper bedrail that the top sits on was mostly rusted through. I got mine for $900 a piece at motorcity k5 and was just happy to find them as they are scarce and just become available at random times. I was told the chinese factory that makes them does limited runs depending on demand
Thanks for the pictures. And at the B-Pillar the welds are quite obvious. right? Because then I'll buy the complete bedside and replace the entire bedside instead of patching the parts together. The one 76 - 91 should be a direct fit for me.
