Every other engine I've ever built I consider mild, this one I do not, I speced and ordered every single part one at a time after I planned the whole engine build for months. It's a pump gas motor with mostly racing parts, but definitely
not an all out spread port racing motor, and no titanium or belt drives were used in the making of this engine.
Dart Big M sportsman block
Callies magnum crank (4.75" stroke)
Callies Ultra I rods (6.700")
JE pistons (4.600 bore, 11:1 compression)
Bullet cam (.810"/.778" lift, 280/
[email protected], 315/328 adv, 114 LSA)
Crower .937" solid roller lifters
ProGear dual roller timing chain with stamped steel timing cover.
RFD/Brodix conventional rectangular port heads (~380cc ports, 2.375"/1.84" valves)
7/16" dual taper pushrods
T&D shaft rockers
Edelbrock Super Victor II intake (I modified it for EFI and welded in bungs and rail mounts)
Accufab 2200 cfm 4500 style throttle body
Moroso vacuum pump
IGN1A coils
custom 36-1 crank trigger wheel
Holley Dominator ECU
The trans is still the same 4L80E OD trans I built 6 years ago or so. Although I think I need a different converter, this one is strong triple disc 10.5", but I want higher stall
The rearend is a fabricated 9" with a 9.5" 3.60 ring gear and spool with 40 spline strange axles. I am selling the 12 bolt I had in there before with the 35 spline spool.
I've had a spool in it since before I built the 4L80E for it, I had a tight eaton posi in it for years, but sometimes when I drove it to the track if the tires came out of the water box uneven one side would spin and not heat up right, so I sold the posi.
The Holley ECU controls the engine and trans and half the car at this point(both fuel pumps, water pump, both fans, etc) I have sensors all over to datalog stuff during the runs. I can even monitor transmission pressure and temp, oil temp, differential temp, etc. Temp sensors are only $10 to add one once you have the ECU, so I have them all over. With the trans having stock turbine and output speed I can even monitor converter slippage and any wet clutch slippage.
The funny thing is the paint and wheels are exactly the same my father and I did back in 2005 after 10 years of it looking bone stock, so the car looks the same on the outside, but is almost entirely new on the interior and chassis/suspension/steering. I tried to hide the chromemoly cage as best I could, tucked it up real nice.
