I'm not too sad. I hope they total it so I can move on. It was needing a fair amount of work and I'd rather have a gasser up here in this cold country.Sucks about your ferd
Yeah hope so, my wife was like "can we just move back to moab" lol.Damn man sorry to hear about rough start there so far. Hoping things turn around for you real quick.
My starter barely cranks over now. Ordered a gear reduction style starter and bracket off Amazon. With 2 day shipping it's about the same cost as an OEM replacement from napa. Also found these in stock at my local AutoZone. @nutt7
Hopefully swapping lines on the MC and rebleeding the brakes will get the fronts to lock up before the rears in the snow.
I checked the surface where you had the machining issue for the line seat and they looked ok. We will see later this week when I get a chance to put them on .I hope you don't have the same issue I did! Make sure the lines seat fully.
Gotcha! Just considering it since I already cut holes in both for my shock towers and I could just gut it out and box them in with sheet metal and have it sprayed or reinstall carpet afterwards.Noisy and cold yes
Just put a tarp down
My linkage was barely out, like I didn't think it was the problem but I shortened it up about 1/8" if that. I will have to do some more driving in 4 hi to make sure it's fixed. I just popped it in for a few miles with my hubs unlocked and it didn't fall out like it was before. @GWeakland620 do you work for lkq?My 4hi does the same thing. Pop's out under a load. I really hardly ever use 4hi, but there are a couple situations where I'd like to use it. How far out of adjustment was it?
Yes sir I do.My linkage was barely out, like I didn't think it was the problem but I shortened it up about 1/8" if that. I will have to do some more driving in 4 hi to make sure it's fixed. I just popped it in for a few miles with my hubs unlocked and it didn't fall out like it was before. @GWeakland620 do you work for lkq?
Any leads on a bw1354 manual shift tcase for a 95 mazda/ranger and the shifter and linkage? I need to call my local salvage yard and see what they have. My electric shift one split the rear case and its stuck in 2 wd low some how.Yes sir I do.
How much and shipping?Our North LV yard has one. 97k miles on it.
83401What's your zip?
