What a day! Everything seemed to go smoothly. Spindles each came off with two whacks with a sledge hammer and 2x4, right knuckle took some persuading. But the left one, unreal. We forked it top and bottom, whacked on the castle nut until it started to strip, luckily we got it off, we hammered the threaded portion of the ball joint. We took the yellow propane torch to it, re hammered, reformed, finally after almost 2 hours, it fell loose, but by then, we had hit the top of the ball joint so much it had mushroomed and would not slide through the axle housing. We ended up taking the top of the mushroomed threads off with an angle grinder. Sparks and stinky fumes everywhere.
