- Joined
- Feb 17, 2000
- Posts
- 1,009
- Reaction score
- 185
ill check on this before tightening up u-blots on the leaf springs. thanks
You can check these u joints easy without taking them out.The sway bar can be disconnected (as many members have done) and it has no effect on the steering, so that little gap isn’t the issue. Looks like someone didn’t have the correct bolt and used the washers to take up space.
Your symptoms don’t sound exactly like this problem, but if your axle shaft u-joints are rusted/seized then it will cause a sticking while turning. Only way I know to check for this is to tear the axle apart and check for free movement of the u-joint.
I cleaned and checked for cracks and no cracks found.View attachment 402777
It does look like a frame crack. Inspect the leaf springs and how old are the leaf spring bushings. Have you checked wheel bearings? The other thing that the rig might benefit from is getting rid of the push pull steering and looking into crossover/high steer. Just my 2 cents.
