73redblaze
I have always wanted to make a build thread but when i built my 73, it was nothing to impressive. Now im building my 84 and again, no to impressive, but its getting better so hell with it, im starting one. I bought her 100% stock in 2009.
the truck
1984 chevy k5 blazer
power everything
gas tank plate, trany cooler, oil cooler, trans gaurd
84k orig. miles, Edelbrock carb and manifold
700r trans, np208 t-case
suspension:
64s in the rear with diy4x shackle flip kit 6" shackles
56's in the front with DIY4x front and rear hangers with 7.25 DIY4x shackles.
14 bolt FF, turned up, welded
Dana 60 mods pending
WFO conepts spring plates
pro comp es9000 shocks with ford shock towers
Home made anti wrap bar with DIY4X shackles and axle mounts
Steering:
Ballistic fab one ton tie rod with heim joints
Ballistic fab one ton draglink with heim joints
WFO concepts drop pitman arm
Tires:
KORE 15" steel beadlocks (real beadlocks) pro. welded and mounted
37" boggers
the truck
power everything
suspension:
Steering:
Tires:
37" boggers
