Is there enough room in the starter bolt holes and block material to hog them out to the next size up for some added strength?
Thanks guys.. I'll slam the seperator on tommorow. Hope me and @bergerking and @Dil.Pickle can go wheelin big bear next weekend. Now I am satisfied that I have fixed it. Hope nothing else goes.. Lol
In the block mine had a bolt not a stud, it was smaller than the starter bolt so u assume like 1/4 maybe 7/16 if it breaks I'll drill and tap the hole larger.
But the bracket.. Making one was a huge pita.. Trust me
My tank switch valve isn't working, funny thing is I don't even care.. 20 gallons seems like plenty..
Those things piss me off. Just sayingMy tank switch valve isn't working, funny thing is I don't even care.. 20 gallons seems like plenty..
Tank switch valve. Mine no longer has one
Mine actually does real well on fuel
Switched voltage was correct but not enough amperage to fire the solenoid open. I bypassed it like kay86k5 did on his crew. Still have both tanksWhat caused you to yank it? Leakage? Solenoid failure?
Not anymore, bwahaha!Does it draw from both tanks?
I am tempted to go to an electric fuel pump.. Just for priming purposes even.
