Don’t be hatingRockin your wife’s sunglasses
Over an hour, it froze externally.Interesting the system is freezing, how long did you pull a vacuum on it?
Must be all the humidity in the desert?Over an hour, it froze externally.
I've seen it. Even with low humidity if you go low on the fan speed but max cold on the temp there isn't enough airflow to blow the condensation off of the evaporator. Do that long enough and the condensation freezes. Yes even in low humidity condensation happens.Must be all the humidity in the desert?
Yeah I know. It just sounds like a good case of irony. When I was mining I would crack the heater valves on the equipment just slightly and it would keep things thawed out.I've seen it. Even with low humidity if you go low on the fan speed but max cold on the temp there isn't enough airflow to blow the condensation off of the evaporator. Do that long enough and the condensation freezes. Yes even in low humidity condensation happens.
Classic symptom is the air flow decreases gradually to the point you have no airflow. Turn the temp up and in a little bit the evaporator thaws and airflow comes back.
If it was a stock ac system it would have enough bleed through of heat in the heater core that freeze up is really rare unless you put a manual ball valve on the feed side of the core.Yeah I know. It just sounds like a good case of irony. When I was mining I would crack the heater valves on the equipment just slightly and it would keep things thawed out.
You need a nv4500 for that awesome overdrive gear don’t you?!Booooooooooooooooooooooooooooo ooooooooooooooooooooooooooocrapooooooooooooooooooooooooooooooooo
How much you want for the whole nv4500 setup. I want it lol.You need a nv4500 for that awesome overdrive gear don’t you?!
See, problem solvedHow much you want for the whole nv4500 setup. I want it lol.
See, problem solved
And no. The only place I need OD with these 37s on the 4.10 is above 70. Only about 5-8% total drive use at that speed. Not much margin on utility
What trans? I've got a sm465Mine runs 3000 at 80. Honestly run 65 most of the time due to traffic and terrain.
