B big4x4ride 1/2 ton status Joined Feb 11, 2004 Posts 216 Reaction score 0 Location Corpus Christi, TX Aug 9, 2009 #1 Can't fine the answer in any of my diagrams, what wires go to the oil pressure sending unit, and to the temperature sending unit?
4X4HIGH 1 ton status GMOTM Winner Joined Dec 14, 2001 Posts 22,423 Reaction score 662 Location Fremont, CA. Aug 9, 2009 #2 Temp sender wire is a single green wire. I can't recall the color of the oil pressure gauge wire.
fmstruck 1/2 ton status Joined Jan 5, 2008 Posts 302 Reaction score 0 Location Fairbury, NE Aug 9, 2009 #3 The oil gauge wire is usually a female spade with a grommet that is kinda formed to fit over the sender. I can't recall what color it is either.
British Slave 1/2 ton status Joined Jul 25, 2007 Posts 2,086 Reaction score 2 Location Gonzales, Texas... The home of Texas independence. Aug 9, 2009 #4 Wiring diagram shows oil pressure sending unit a single tan wire. The coolant temp. is two wire, a yellow and a black. Look here: http://brochures.slosh.com/wiring/
4X4HIGH 1 ton status GMOTM Winner Joined Dec 14, 2001 Posts 22,423 Reaction score 662 Location Fremont, CA. Aug 9, 2009 #5 British Slave said: Wiring diagram shows oil pressure sending unit a single tan wire. The coolant temp. is two wire, a yellow and a black. Look here: http://brochures.slosh.com/wiring/ Click to expand... The temp gauge uses a single green wire. Don't get this confused with the coolant temp sensor used on the TBI vehicles (those are a two wire sender).
British Slave 1/2 ton status Joined Jul 25, 2007 Posts 2,086 Reaction score 2 Location Gonzales, Texas... The home of Texas independence. Aug 9, 2009 #6 You are correct, and 85 didn't have TBI. Not sure how I got that one wrong. So it's a tan and a green.
